IPR Full Resolution
Is it possible to IPR at full resolution?
For example if the final rendered output is 2000 x 3000, can you IPR at that resolution, or only the floating window resolution?
Only the window resolution, so you’d need to make the window that size.
Is that to say that if you ran the IPR on a second monitor - vertical or horizontal rotation - that could support the desired rendering resolution, you could essentially full-screen the IPR on that monitor and deal with it that way?
Of course, this seems cumbersome even if it is possible. Running IPR at the output resolution is possible in Vray, and I expect it is possible in Corona, but I imagine there is some upscaling or downscaling that is required (?)
