IPR in viewport problem
I just want to inform about weird behaviour.of IPR in viewport. I got nightli build from yesterday (11.6.) and render is bigger in width. I tried max cam and vray cam, its the same.
I found out this problem is caused by Show Save Frames. When I disable it, its ok.
We are aware, it will be fixed. Let me remind you that this is a feature that exists in the builds only for a couple of days :slight_smile:
:-)ok, sure :slight_smile:
As a user of betas, I think I should post any problems just in case you know.
One more thing, when region render in standard VFB is used, viewport rendering is bad too. I just let you know.
In the beta group, not on the main forum.
It’s a closed beta for a good reason. :slight_smile:
Sorry, I am probably blind, but cant find beta forum for 3ds max. There are betas for other programs, but I dont see one for max.
I did write *beta group*, not forum section. :slight_smile:
It’s a google group you should have gotten access to when you had access to nightlies.
