Hi. Not sure if this is the intended behaviour but there are a few cases I’m coming across where a IPR refresh isn’t needed, not sure if you can do anything about it.
Compact material editor and slate editor : when “clicking through” a material, so entering a map or whatnot, a refresh is triggered (90% of the time), even when no parameters are changed.
Switching between compact and slate material editor.
When using the eyedropper to add a material in the slate editor.
I’ll report more cases if I come across them, as I want to use the IPR more.
