Hello
No particular issue, just was wondering if it is necessary for IPR to be refreshing with also any change. Like for example going from full frame to region render ?
I dont know if this will be updated at some point just was curious.
Thanks.
Stefan
The refresh when changing/adding a region is a known issue that’s on the “To-Do” list to be fixed.
If you see other cases when IPR restarts without need - write them here too.
Yavor
ouh that’s great ! i will keep the loop open when bump to something else.
Stefan
