Would it be possible to set up the IPR as low priority CPU mode, a little like what you can do in the taskmanager, this would allow us a little more interractive command on the material editor and all other 3dsmax stuff !
In IPR the priority is already at lowest and we use one core less. You can see the number of used threads and their priority in the Stats tab in the new frame buffer.
Yavor
OK thanks, why does 3dsmax behaves so slowly then when you want to edit something (geometry/light/materials) ?
