Deleted content.
Hi!
Unfortunately, The version of Corona Core (which is what you pasted) is not enough to see, what version of C4D plugin you have. Use the “About” dialog and copy the version string from there. And in general, try the newest daily build and see, wheteher the problem is fixed there.
Also, are you starting the IR correctly from the VFB? Note that there is no such thing as an “IPR framebuffer”. There’s just the Corona VFB, which can be showing output from normal render or interactive render. To start the IR, just press and hold the “Render” button and then click “Start IR” (See image).
As for the crash report - try it in the newest daily build please. If it’s still crashing there, you can send us the crashing scene/LUT file through our private uploader (see my forum signature).
I hope we’ll sort your troubles out!
No problem ![]()
So what about the LUT crash? Is it still happening to you?
I reported the LUT problem to the core team. The IPR vs. normal renderer issue is more of a UI issue, but not a bug. I am thus moving this to resolved.
