I get strange results when the IPR option “Use out of process IPR” is enabled. See attached renderings.
Maya 2017 Update 4
VRay 3.60.01
Cheers, Florian
If you could share the scene with the problem it will be very useful. I see that it’s a very simple scene but I’m unable to reproduce it on my end with pretty much the same scene.
Hey Ivan,
here is a Maya file that produces the error on my machine. The scene does render correctly with the latest Beta (Build 27683)
Cheers, Florian
outOfProcessBug.mb.zip (131 KB)
Thanks for the scene, I’m happy to hear that the bug isn’t reproducible anymore. I’ll still check it with a previous build in case there is something else. Since you’re using the stable nightlies I recommend updating to the latest 27689 build.
