Not sure if this is known, and it might be a problem for iToosoft to solve, but whenever I activate IR, either as floating or viewport, the forest renders fine but the entire forest disappears from my viewports. Not just invisible but the object itself isn’t in the scene explorer. Somehow it’s being hidden.
I think I can confirm this. It looks like the objects get hidden while rendering to conserve memory so it would mean that Itoo Forest is not compatible for Corona’s IR. I am not sure, though.
The forest object does render fine in the IR itself, here. It just gets hidden in the viewport while it’s active. Fingers crossed you/iToo can find a solution. IR is indespensible, as is FPP
I wonder if actually this might have something to do with the other FPP bug where after rendering the viewport is filled with the average colour of the FPP in the viewport. e.g. if you have load of trees that are green tone, when you cancel or finish a render the viewports are filled with that colour. As far as I’m aware iToosoft are on the case with that one, so perhaps it’s related somehow.
Have the same problem with FPP v5, but with FPP v4 everything is ok. If someone else can test also with older version of FPP to check if its a problem only in v5.
Testing with Corona version 1.5.2 and FPP 4.4.1 - It happens as well that the viewport scatter turns to little orange crosses (unselectable though).
To re-select and edit the FPPs in the scene I can only work with the object selection dialog unfortunately.
Would be lovely to see this sorted (by either Itoo or you
Cheers, thanks!
We have the same problem here. The forestpack object disappears in the viewport whilst an IR is running. It reappears as soon as you stop the IR.
Corona 1.5.2 and Forest Pro 5.2.0
Personally I’m using Corona scatter as its simpler and easier, plus the viewport gizmo makes selecting the scatter much much easier (always hated how hard it is to select a forestpack object). But for new Corona users here, the first thing they reach for is Forestpack so its a shame its not working right.
Is there any update on this? Getting things right in the viewport, is slightly faster than IR so it’s a bit of a pain for it to disappear in the viewport…
Same problem here with Corona 1.7 and MAX2018, when i start the IR the forest object disappear in the viewport, that’s quite annoying… No solutions at this time ?
Hi guys, this is a known bug. If I am not mistaken Itoo is looking for a solution. But to be sure about that, do a search on the forum. I cannot remember in which post this was mentioned.
