IR crashes using paint areas in Forest Pro and autoback saves but looses paint
Has anyone else had Max crash when using paint areas in Forest Pro while IR is running? The last two times today it crashed and offered to save the backup. But when I open the recover file the painted area is gone. Thanks
Are you using the newest version of Forest and Corona?
Can you provide exact steps how to reproduce it?
I’m using Corona 3 Hotfix 1 and the second to last Forest Pack. So I’ve updated the software and will see if it happens again. Thanks! The steps are:
Enter paint mode in Areas of Forest Pack and paint some areas
Start IR in Corona
Continue painting and I can see the IR update as it’s suppose to
But then it crashes with an option to save the backup
When opening the max backup file the entire area is erased and needs to be painted again
