IR exterior scene
Daily Build 2019-05-03
I have an exterior scene, several trees, grass, etc. (3.5 million poly total). IR rendering is a crash with every change.
I am doing something wrong?
For crashes, we’d need the bug report, and a copy of the scene is most useful too. See https://help.c4d.corona-renderer.com/support/solutions/articles/12000033461-how-to-report-issues- which covers all the info on what to submit to us :smiley:
I sent the scene. Does it look like a combination of multi-instances and mograph shader effector?
thanks
Did you also send the bugreport? That helps in case we don’t have the plugins / can’t reproduce the crash here, as it tells us exactly what Cinema 4D and Corona were doing and what error they ran into. Cheers!
Of course, bugreport also.
Excellent, thanks!
Just a bit of a heads up. The multi-instances aren’t currently supported in IR :\ You need to switch back to the good ol’ regular instances for now which obviously isn’t perfect because viewport speed goes tralala out the window :smiley:
