I use itoo plug-in software everyday, and I notice that’s more and more difficult to use them with IR, I suffer from constant freezing (dancing windows issue) this is very penalizing in my job.
I think I have tried everything (autodesk help forum, tweaks and other things …) nothing helps
I will provide you the mini dump as soon as I can.
The schema is always the same, in the presence of a forestpack object a little bit heavy (it is worse when it is selected) the ir freezes and can’t be stopped which causes a complete freeze of 3dsmax
Last version of forestpack (6.2.2) and 5.0 for corona.
We and iToo have identified some issues with IR and we are working on a solution. Once there are some updates, we will be sure to notify you here or in the changelogs.
Currently the status of iToo plugins and IR freezes is that it’s a known limitation, which may sometimes occur.
