IR in A6
Sorry if this is an easy question but is it possible to get interactive rendering in R18 with the new build of A6? I launch the VFB and select render IR but it doesn’t update with scene changes and I dont see an interactive option anywhere.
A similar issue with R17, and before we can do a region render directly in the 3d view, without vfb.Now it crash directly.
same problem here. r18.
otherwise this is a great renderer, congrats to the team, wonderful work.
only wished it had arnold-like node system shader. and better in-depth explanation of the workflow, what each button does( vfb for example).
lighting-wise, my understanding is that i don’t have to worry about lighting exposure while setting the scene, it’s all a post process thing. am i right?
thx!
hi there,
i was just about to post an similar question..
is IR there in the cinema 4d alpha? and if so where is it? because using the corona vfb with the click and hold does not work… :confused:
IR feature should be in A7
you can check roadmap here Trello
