IR locked again at PTS = 4. Why?
Hello Ondra,
some times ago, I noticed this “problem” with IR: PTS was locked at 4.
In some old daily, you solved this problem.
But, in the last, I cannot change the PTS.
In some situation, like dark glossy plastic, I need to wait minutes to see a good preview.
Con you add the possibility to change the PTS also in the IR?
Because, incredibly, with the producer version, it’s faster!
Thanks!
It is not locked. Change GIvsAA to a higher value like 999 and you will see it will become much slower.
Hi Maru,
mmm… you are right.
I don’t know why in my test it was not possible. Maybe because it was an old file…
Thanks for the answer =)
