Hi im just having a go at a walk-thru test and i understand that its good idea to use the gi blur to smooth the ir map,only problem is when i use it i get these results,black splodges! :?
gi blur set to 5
One question,if i did have say an area within this walk-thru with high detail,and used the GI blur to smooth the detail,i would still have this problem in this low detail area?
How would i go about fixing that? :?
try changing the sample lookup method … you need to have more samples with Desnsity based to get smooth results.. also try ticking Check sample visibilty.
