IR : Material layer not updating correctly
Deleted content.
Yes, IR might still have some troubles with updating, because we have to detect all changes ourselves and manually update everything that changed as well as any dependent settings that might be connected to those changes. But every single bug with IR updates is actually a different issue, so please report them as such. Thanks :slight_smile:
The layered material should update OK in the next release candidate.
Can you please confirm this is fixed, NEO-N? Thanks
Before you close this and consider this fixed. Yes, layers update when done manually inside the material. both masks and shaders. Xpresso driven stuff does still have the problem.
Damnit, Eddoron! You and your Xpresso stuff! :smiley:
I’ll have a look at it, but a separate thread would be nice :wink:
