Hi - this might be a known issue, but I couldn’t see any other threads discussing it.
The interactive renderer doesn’t update correctly when working with fields in R20.
I’ve attached a scene with a simple setup (a cube in a cloner object set to array, with a plain effector modified by a linear field in the falloff). When the IPR is launched, it initially renders correctly. If you then change just about any parameter in the effector or the field, the IPR ignores the field and applies the effector to all the clones.
In R19, the IPR seemed to work fine with falloff.
I’m on a Mac Pro running High Sierra 10.13.6, with C4D R20.059 and the Corona Daily Build from 27th May (core 4 (Release Candidate 1)). I was also having the same issue with Corona 3 - Hotfix 2 and I think Hotfix 1 as well.
Hi Dylan, I tried it myself and can confirm this is happening for me too (on Windows as well). We’ll have a look at the issue and see if we can fix it.
I’ve just had a go with Corona 4 RC4 and Corona 4 Hotfix 1 and seem to be running into the same issues.
Is it something that we should expect to live with for a while? Just trying to decide whether to start our next project in R19 or R20… would love to start using R20 with Corona.
The fix for this issue is planned to probably appear in Version 5, but I cannot promise anything more specific, I’m afraid. For now, we don’t even know, whether the fix will be easy or whether it will take a lot of time. So as for your question - I wouldn’t count on this being fixed in the next few days or weeks.
Thanks for the reply and looking forward to the update.
Needless to say, falloff is a crucial part of mograph and this bug dramatically affects the usability of the IR (at least for me). No doubt it is one of many things on the list, but don’t leave it too far down!
