Whenever I use IR, when I resize the window, the render doesn’t scale up or down. I don’t have ‘locked resolution’ enabled."
Hello @3daltm
does this happen during interactive rendering or when you stop IR and then try to resize the VFB?
hello,
We could not reproduce it so far. Could you please:
- Send us any scene where this is happening for you (it can be a simple box, the important part is that the issue appears there).
- Try toggling the resolution lock on and off (both in the VFB top-right corner where it states the percentage of the current zoom level and in Render Setup > Performance)
hello!
1 - i send a a file and video
2 - I had already tried these options right after installing version 12 H1
thank you
2024-09-25 08-49-19.mkv (12.6 MB)
file max
tetse ipt.max (1.17 MB)
Hello @3daltm
thanks for sharing the files. However, we were not able to reproduce this either with your scene or with a new one.
I reported this as a bug to our devs team.
(Report ID=CMAX-1291)
thanks
