IR or Realtime Update not working ;(
Hello everyone,
i can’t get the realtime update to work neither i can find anything in the rendersettings of corona. I must admit i am using C4D R19, is that an issue?
Attached you’ll find a screenshot of my version.
Best,
David
PS: Working on a MacBook Pro late 2013
Yes, because the ancient version does not have that.
Here’s the latest: https://forum.corona-renderer.com/ Corona Renderer for Cinema 4D Beta 1 Release Candidate
I have downloaded it and installed. The MacOS X Finder tells me the Standalone Renderer been updated today. But the C4D Plugin remains “ancient” (I like that term).
So is there another plugin available as well ?!
Best,
David
I don’t work on a mac, so I can’t help you in that sense. I’d try to manually delete the old files and do a clean install of the latest version.
I’ll do that now :smiley: Thanks
Ok I have found the issue. As I’m running R19 and it’s not in the Corona installation path it simply didn’t find it. It runs now and is smooth as butter <3 Thanks.
Solution:
Make sure to name your R19 Cinema4D folder to R18 and the installer will find the app (also make sure it’s there :wink: )
Best,
David
