Has anyone got any thoughts on how to make a glass shader similar to the attached image?
Im thinking theres some mix of glass, thinfilm and maybe a metal shader but im struggling to find the right balance or create something physically plausible.
I believe its glass but its been coated inside with a metal of some sort.
If you are talking about the bottom 2 spheres, then this is called Dispersion. In the legacy material its 1 below Refraction.
Ill have a go thanks. Im not 100% sure that its dispersion it looks to me like a coating
It looks like a job for the Siger’s thin film texmap. SIGERTEXMAPS ThinFilm – Siger Studio
Yeah ive got that and had a play around with it. Its sort of halfway between metal and glass which is where im getting stuck because obviously its physically possible but im not sure how to make that physically based in corona (v6)
+1
I really do love Sigers plugins.
Use Siger thin film on a glass shader and then add roughness to the coat layer in the new Physical Material Shader, or create a layered material to add the dust / dirt.
For all intents and purposes the reference image shows, basically, a “dirty bubble” shader.
I don’t think thin film texmap can be successfully used with Corona physical material, at least not in a way it’s intended to. I think you need to use legacy material, which of course doesn’t have clear coat.
My experiments back during the dailies of 7 when I wanted to know how this kind of look would be handled with the new Phys Mat suggests using the Absorption in the Clearcoat (basically, an extra coating of some sort of oil-like material on top of the base glass). Just remember that the clear coat colors everything beneath it, so don’t make the colors too strong (else it will start to look like colored glass
I thought this was shown somewhere but I can’t find it, so here’s the scene re-opened and screengrabbed, I think with some playing it would give the desired kind of effect.
