irradiance map calculation in animation
is it safe to DR IRmap calcutation for animation?
regards
Ryan
Ooh, I would like to know this too.
DR DOES DO .9 pix aspect, correct?
You can’t do DR with animation, can you? Maybe in later builds…
its only available in the later builds
Even though you can use DR for animations, the incremental add mode for the irradiance map is not supported in that mode as of yet - so no, you can’t use that to DR an irradiance map for animations.
