Is .crx available in Corona for C4d? I´m very interested in the option of make discontinued renders, start a render in my job and continue it in my home for example.
Yes you can save to CXR from the Corona VFB and use Resume File from the Corona VFB to pick up where it left off (or just use Resume Last without saving the CXR file, if you have not cleared the VFB).
TomG,
both in vfb of corona and pv i can’t find the extension cxr when save the render but only in exr. Could you explain the procedure for saving the cxr?
Version used Corona for Cinema 4D Beta 1 daily build - 2017-09-05 Mac and Win.. is the same problem
Can you give more information, such as the steps followed, Mac or PC, etc? Also, does the saved cxr look correct when opened in the Corona Image Editor for example?
Here’s what I tested and it worked (C4D R19, PC, latest Corona daily)
Load scene
Render in VFB for 10 passes
Save to CXR from the VFB save dropdown
Close C4D
Reopen C4D and reload the scene (the same scene has to be loaded)
From the VFB, choose the Resume file option from the Render dropdown
Hi Tom,
I’m on OSX (MacPro Xeon), R18, latest build of Corona. I did your steps except closing C4D.
After loading crx, image in VFB is black. Will do test again tomorrow, now I have to finish some work.
Thanks!
mac
