I have an upcoming project with boats, ships and all things on water and was looking at plugins/software for the water, foam and wake effects with the least amount of effort/render times/complications. So far Dreamscape looks like the plugin to get. Would you agree on this or is there something else that could work?
I think realflow is overkill and would take forever to calculate and I’m not sure if it is even what I need.
I have tried dreamscape a few times, it can work pretty well. I have found it works for big ocean waves but is harder to get tighter detailed gentle waves, getting the scaling right seems tricky. Also depending on viewing angles it can tile quite badly. For general waves I have often found good old VRay displacement does the job.
As for wake and foam, I havent tested dreamscape thoroughly yet for this
i had a good time with frantic’s floodsurf, it had an excellent dither something that removed tiling very efficiently, foam and wavecrests was a breeze to set up with the provided shaders and there was no problems with vray…i think it is dead though - what a shame
Floodsurf is still on Frantic’s site although like you said it seems dated. Also it seems more expensive than dreamscape and I would also have to get Flood together with floodsurf. Anybody else have info on this?
hmm, i’m fairly sure you won’t need flood for floodsurf, unless something changed since early beta. imo the 250 extra is totally worth it, if it’s still alive that is…
Ive messed around with dreamscape. I liked its foam map generator, though didn’t use it in production. I was kind of turned off by the tiling of the waves though.
I use dreamscape - it works very well - I have no issues w/Vray & dreamscape combination. (Vray1.5 SP3 / 3DS MAX 2009).
Works very well for calm sea scenes. I think Realflow (www.realflow.com) is better for storm scenes - main reason for this is that you get the dynamics of the boat interacting with the sea (and visa versa) + fluid particles / mesh. But this is much more complicated software to learn/operate.
Hi DVP3D. I have a similar project coming up very soon. I just wanted to know what you chose in the end ? Did you manage to produce realistc foam and wake ?
Any further advice would be appreciated. I am looking at floodsurf and dreamscape.
i wanted to buy floodsurf
i received a mail from frantic support saying they stopped releasing it, but that they may ship it again, depending on the customer response.
I haven’t done anything yet for it (its only coming in a few months), but unless something major changes soon (which I doubt) I will probably go with dreamscape. I mailed them and they said they will be bringing out a new version of it (although not soon). For my needs it seems dreamscape is perfect. haven’t yet looked at the new vue 7.5 to see if it might be able to do what I want.
this is what I do with Dreamscape and Vray. The model was designed with Rhino.
Wakes were generated before with a simple model of the boat…foam is a bmp sequence generated by Dreamscape during the simulation.
This is a shot taken from a 2 minutes animation.
Cheers for the info. Unfortunately the project didnt come to fruition…at least I can refer back to his thread. I may try some boat imagery at some point anyway.
