Could you tell me, is GTX 980 Ti with 6GB video memory good for work in 3DS Max? I’m not talking about GPU rendering now, I’m thinking about viewport performance at the moment.
Now I have GTX 660 Ti with 3GB, and I’d like to get better performance. It would be also interesting to know if you have better price/quality balanced video card for this case.
Yep the 980 Ti is good, still using one here myself. Of course, the new 1080s are even better, haven’t looked into the price / performance ratio though to see if the 980 Ti is down in price enough to make it still worth considering compared to the 1080s.
For sure on choosing one of the newer generation cards - unless you are saving a lot of money by purchasing the older generation, go for the newer ones. Most likely will have to upgrade soon again myself
I run this test on my gtx 960 some time ago, results was pretty similar like gtx 970. For 3ds max alone, gtx 980 ti is not worth its price. I’d go with gtx 1060.
BTW, difference in fps is most likely more from different windows and max versions rather than from GPU itself.
3dsMax is indeed quite inneficient with GPU when it comes to handling scenes, imho there is way more overhead somewhere else.
Choice of GPU comes down to what else you also want to use it for. Even 1060 is pretty damn good gpu. 1070 will be improvement when it comes to real-time mostly.
Now I’m facing another problem, it’s connected with power supply. I have only 6-pin PCI-E outputs there, but video card needs 8-pin connection to power supply. Searching adapters 6->8-pin in internet didn’t give results… Do you know any solution for this problem without changing power supply block?
That should be more than enough. And judging by manufacturers info, that PSU should come with 6 cables that go into 6pin plugs in PSU, and have 6+2 pins on the other end. Those are the ones you need.
If you don’t have those, try ordering spare ones somewhere. No need to change PSU
