Is precalculated irr map resolution independent. I just rendered anim at 648*365 but now I’ll have to make it pal resolution. Can I just render it again with different resolutin or do I have to calculate the irr map again? And I’ll propably make hires still from one of my frames. Can I go with the same irr map or?
No, it is not resolution independent. Though you can use your existing imap, it will lose a little detail, like lowering the min/max. Each time you double your output size it is equal to lowering the min/max by one. Best to try a frame and see how it turns out.
