Just curious if it is necessary or advisable to increase the displacement size as the image size increases?
I’ve been having trouble rendering an 8k image, which just crashes when calculating displacement… I’ve enabled 2.5D and after upping the value from default 2 to 4 it seems to have got through it and is now rendering…
I’m running a TR3970 w/ 128Gb Ram which I would think was plenty? the scene also seemed to render ok with the default settings at 5k…?
With 2.5D I am frequently rendering 8K images even with 1px size with no issue, never even touching above 60GB I believe. With previous disp method, that was impossible, 3px was the highest for such resolution and precomputation took forever.
Any suggestions as to what might be going on? I’ve rendered other angles from the same scene at 5k without issue, but the last one they want at 8k just crashes everytime…
I’ve changed the secondary GI to Path Tracing and enabled 2.5D and upped it to 4 which has seemed to get it going… but I haven’t seen the result yet so not sure if it’s going to be okay…
it’s just an exterior townhouse scene, forest pack, basic brick and render townhouses…
Thanks Maru, I was unsure if I could send the model - but I realized what the problem is.
I was displacing a 576.000.000 m2 terrain at rendertime, at 1 px subdivision quality.
I can imagine that working perfectly fine, depending on the output resolution.
For screen-space displacement it doesn’t make any difference if you are displacing a 1x1m or 100x100km plane.
