Is it possible to save individual render layers as a vrscene files automatically?
… I currently use the <Layer> token and vrend command to save each render layer one by one. Is there a more automated way to save all active render layers out of the box?
Thanks in advance
If you set your scene to export a vrscene instead of rendering, a batch render will go over each layer and each camera and export a vrscene for those.
I’m not in front of Maya right now, but in case we don’t automatically add the render layer name to the vrscene, it might be a good idea to add <Layer> to the vrscene export name.
Also - there’s a batch render command-line option to only export. For example, something like this should not render, but export a vrscene.
Render -r vray -noRender -exportFileName C:\temp\scene.vrscene
Super helpful. Thanks Yolov
