Is it possible to set preferences for each scene?
Hello Forum,
I saved a few scenes in SketchUp. And when I render them, I click each Scene in SketchUp. But how is it possible to adjust different Settings for each Scene? For Example Sun Brightness, Color Temperature or Cloud Density?
Thanks in advance,
Greetings, Peter
You need to set the scenes in Enscape via the View Manager, not as you normally would in SketchUp. I always forget and it’s a bit backwards for me to think that way. And appears there is no way to take existing SketchUp scenes and “send” those to Enscape. EDIT <---- You can, but need to set up presets and apply them individually to scenes. Basically you end up with presets for each scene which can get messy if you have a ton of scenes, IMO.
https://enscape3d.com/community/blog/knowledgebase/create_select_view/
Thanks a lot Tim! I give it a try!
