My current system has a GTX 970 with a 750 Watt power supply.
I want to purchase 2 GTX 1080 Ti’s. To install them WITH the GTX 970, I’m told my 750 Watt power will not be enough and I will need a 1000W power supply. So there’s another $300 on top of everything. Or, do I just get rid of the GTX 970 and stick with the two GTX 1080 Ti’s.
I’m trying to keep as much rendering power as possible but is it worth spending the extra $300 to keep the GTX 970? Or will the performance boost combined with the 2 GTX 1080 Ti’s not be worth it?
When you download the driver, you’ll notice the “Supported Products” section on their site. You’ll see most cards use the same driver (same download file)
im wondering about getting a 1080ti, but isnt there a new ‘2080’ coming out soon? Unsure what the pricing/performance difference would be and if its worth waiting?
Will rendering with the GTX 970 and the two GTX 1080 Ti’s improve performance or will the GTX 970 present itself as a bottleneck? I know I’d be limited by the smaller amount of memory on the GTX 970 but would that be the only bottleneck?
When you have adaptive rendering, the scaling in some scene might not be as linear. Usually you can alleviate that by setting higher “rays per pixel” values from the V-Ray GPU settings - this will make V-Ray giving bigger chunks of data to the GPUs, so they will be more utilised. It often helps a lot.
I can’t say for sure though, it is best for you to test and see how it works for you. Probably just get 2 x 1080ti and 1 x 970 for display, and if it is not as fast as you like, go for one more 1080ti in the future ?
