Is TextureObjMask compatible with corona?
I tried searching but didn’t find much. Does anyone know if this is compatible with Corona? Or does Corona have a similar method?
I want to use in animation to reveal as a mask.
So far It doesn’t seem to be behaving like I thought it would. But totally possible that I’m not building it out right.
I’m not sure how TextureObjMask supposed to work, but did you try CoronaDistance map? I think you should be able to achieve what you need with it.
Oh thanks. This works great! It’s a little more complicated to get setup. But it’s going to work perfectly.
