I have a system with XP pro 64 bit and am running Max 9 64 bit. I noticed when the system starts up it only displays 3.5 GB of RAM even though I have 4 GB installed.
I have been ignoring this but I am back to crashing max again so i am wondering if the system is using all available RAM. Do I need to use the 3GB switch? Also, are there any there settings that need to be modified so that Max will not be limited in memory?
(My motherboard will take up to 6GB so I don’t think the memory is unsupported).
3 gig switch is only for 32 bit systems. 64 bit apps are allowed by 64 bit windows to use all available memory. This has no relation to your problem.
If you have 4 gigs and it s only showing up as 3.5, as davexl said, its a bios thing. Your mobo defaults may be reserving your “missing” ram for a “memory hole” for hardware components. Find out which setting is doing this in the bios and set it to minimum.
Go into your bios and find the setting that controls the memory hole. The exact setting name is going to vary depending on your bios. Your mobo manual should explain all the bios settings.
and dont forget your allowed up to 128gb physical ram and 9tb virtual ram (or was that 19 i forget) its fun to crank up the computers page file on huge scenes just to see how much memory you can consume
