is there a force to suck in?
Wondering…max has a lot of forces to push out, spin, vortex etc, does it have one that can suck in?.. could be useful, drag does not do that…
you could probably do it with a couple of gravity forces pointing the right directions
i tried it with wind 4 winds blowing towards each other…but once comensates the other…
point them towards eachother, but slighlty towards the point of suction…then rotate them all slightly so you get a vortex effect
well just tested the find target on pflow…works good.
but still max standart particles need some expansion. I found lots of cool plugins on www.maxplugins.de so might be useful some of them.
i dont know if i understood this right.
you can use a gravity spacewarp set to spherical to create a gravitation singularity.
spherical gravity will push it out..
not if you use a negative multiplyer it will suck things in.
will try it.
