Is there a plan to add VRayScatterVolume material
This material can be used to quickly convert models into volume clouds
Hey @123456_1 ,
Since V-Ray 5 Update 1 (noted in the changelog from in the link) we integrated the V-Ray Scatter Volume material inside the V-Ray material. You can use it by going in the Refraction group in the V-Ray material and under the Translucency tab set the Translucency type to Volumetric and start playing with the various parameters until you achieve the desired effect.
Here is a quick example I made for you that could be used as a starting point (IOR should be set to 1):
Thank you for your reply. It was my negligence
