In the file I’m working on, multi-submaterial is changing the color tone of more than 50 objects
I would like to change the maps connected to the multi-submaterial to Corona Color correct collectively.
Now, I’m directly entering numbers into addtional outputs from corona color Correct, and I’m directly putting them in and adjusting the value, is there a script or a good way?
Here let me thank you again James for this awesome script. I use it all the time, not only for vegetation, but every time I have to batch color correct materials, it’s a fantastic time saver, thanks again!
You’re welcome Tom. Ah yeah in hindsight I probably should have just kept it as "Additional Tools’ instead of Vegetation tools or something, can be easy to overlook if you dont know what the script is for.
