is there a way to turn off primary visability on Aerial perspective
hello, i would like to make aerial perspective off in primary vis, is there a way to do this
atm i get this
and my base render layer looks like this
scene file here
https://www.dropbox.com/scl/fi/oo39q393178nky0m6jn39/areal\_issue.mb?rlkey=o0dk63jv3okupun08s3u6dgh7&dl=0
thanks
matt
You wish to isolate the black ball, right? You seem to have overcomplicated stuff with render layers when you can simply render with a Render mask (isolate selected mode; Render Settings > V-Ray > Image Sampler > Render mask).
Otherwise, the reason it won’t work is that you cannot apply object properties to VRayAerialPerspective (not an object). What you can do is put the VRayAerialPerspective in a collection of its own and set an absolute override for the “Enable” option. This, however, will disable it completely.
Hi Alek
thanks for your reply, ill give that ago.
I usually want it rendered against black so i can upremutlitply before using mask to cutout
if i use your first method will the aerial perseptive creap into the aliased pixels at the edges?
second option wont work as i want the m visible in refls
thaks
matt
Most likely, yes. I’ll test a bit more - maybe there’s another method of achieving what you wish.
cheers alex
Did a bit of testing, however, I cannot seem to find a solution other than masking.
no worries mate, thanks for the effort
cheers
matt
