Is there any ram used log ?
Hello again,
With v3.2, when a render,node was running low in ram, i had some ram usage infos in the Corona Error Message popup, so i could see if my texture maps where far too bigs and so on.
The v4.0 seams not to give those infos anymore (see attached)
Maybe there is a log somewhere to find back the ram usage infos ?
Hi, it seems that the error message maybe cropped. Can you see a scroll bar in the error messaging window? Or maybe you could select the text with your mouse cursor and drag it all the way down to highlight the lower part of the text?
We are aware of this issue and are planning to fix it.
I don’t have any current heavy rendering (but still rendering animation for another project).
But i think it was several times the same error, per faulty renderNode.
