Is there any way to make the Curve Editor window bigger in the VFB?
Is there any way to make the Curve Editor window bigger in the VFB? I am pulling out the curves to the 10x range and trying to work in the small window is cumbersome.
Is the any way to expand the editor window? I would love to be able to fill the whole screen with it.
Also - is there any way to add additional points to the curve.
I’m still at v 1.5x
Thanks!
You can add points by holding the Ctrl key and then clicking on the curve.
Unfortunately it is not possible to resize the curve window for the moment. I’ve made a note to look into it.
Thanks Vlado, that would be awesome if you could!
