Before vray 5 the isolate locked selection was working as expected, you lock a map in the node editor and you can change other map parameters while showing the locked one isolated.
Now in vray 5 when locking, it doesn’t show the locked map, but rather the final shader with only the selected object locked, which makes this feature not very useful. It was perfect the way it was before.
Thanks for the report. I think the issue is the locking itself. If I select a texture node (make sure objects aren’t selected) and start IPR with Isolate Locked Selection, it works fine. However, selecting another node breaks the lock. I’ve logged the issue (internal bug-tracker id: VMAX-10244) for developer analysis.
