Isolate Selection
First, I so hate the box… what the heck is it for. If I have something isolated, it is for a reason. Second, it isn’t getting past this white box. MAX crashed to the desktop, not surprising, but I open up to this, so I have to crash out of MAX (waited an hour twice). I merge everything into a new scene without an issue, hit render, and back to this. I rendered the front camera, and the only thing I did was switch to the back camera. Any clues, other than breaking the scene down until it doesn’t crash anymore?
How do you even trigger that box? I can’t remember ever having seen it.
I have isolate/end isolate on a quad for ease, so you could try that to see if it helps…
EDIT: Oh I see; it is the pop-up on opening a file that has something isolated. It seems with yours it is not displaying the text or the ‘OK’ button which clears it.
Weird…some conflict or other. Try it with a new scene…make something, isolate it, save it and reopen it to see if it either triggers the popup or crashes…should indicate something.
It happens on every MAX file I open, and I asked on the AD forum a few times a long time ago, but got no real answer. I left MAX open all night and that box was still there, so I had to kill MAX.
Have you tried selecting the popup box and just hitting ‘enter’? Even though it’s not showing it may still accept the command…
Try this very simple file and see if it does the same Dropbox - Error - Simplify your life
It’s just 3 teapots with one isolated and saved like that, so it should trigger that popup as in this grab
Yes, that didn’t work.
No popup when I open that.
Weird, there should be one exactly as in my screen grab. So what happens when you open it…it displays just one teapot or 3?
I just opened it again and I got the isolation box
I found the bugger!
Progress then…of sorts…did it allow you to ‘ok’ it..and there was text visible?
EDIT: Not quite sure what you were showing in the screencast but at least it solved it :slight_smile:
The problem has been found! It is a V-Ray displacement!
https://www.awesomescreenshot.com/video/3042274?key=4a950c82c3046ca7a7ad26f48ae09769
I removed the shift number in the displacement and the crashing stopped. I can’t get that 1/2 day back, but I should meet my deadline this afternoon.
wierd shit…
Yes, it is and it cost me a bunch of time.
This whole thread is extremely confusing. I do not think these problems are related to one another at all.
But they are. I removed the displacement shift and no more crashes. I put it back on, render, and it crashes and doesn’t open again with the same isolation stuck screen.
I spoke too soon. It still crashed and wouldn’t open with the isolated message. I removed the displacement altogether with and it is rendering now. Thankfully, with this material at this distance, I don’t really need the displacement. For the record, I rendered, closed MAX, and opened it again just fine.
It does sound like it isn’t connected but then there seems to be a connection somehow…so a bit of a paradox…unless…
Just a wild thought; The thing that you are rendering, which is isolated, has displacement on it that ‘may’ be causing the error - so could it be that that displacement is
referencing something that is ‘not’ isolated and so causing some weird loop…something along those lines..
It’s hard trying solve these things without any actual scene to investigate, so maybe it’ll remain a mystery :slight_smile:
The isolation thing makes no sense anyway. There isn’t anything isolated and every MAX file I open has it. I reported that to AD many times, but I never got any replies. I’ll record something when I have time.
