Issue about light selection.
Hi there, my name is Fin
I have one question to ask you about light selection. So when I’m saving settings to make batch rendering, all lights in light select map are deleted, is that a bug or something are wrong in my computer ??
ยูฟ่าเบท
Any suggestion would be appreciated
สมัครยูฟ่าเบท
Thank you in advance
You probably need to manualy set the “Render element Output” or try saving your file as CXR and then manualy save all the elements.
Its more of max than Corona limitation.
(This should be in I need help section)
Already in our internal bug tracker, so we will take a look, but it’s possible that it’s a 3ds Max limitation.
(Internal note: id=298817404)
