Issue: Lights are no V-Ray lights, only Rhino lights
I am not happy with the fact that the standard light button no longer generates V-Ray lights as in the past. I don’t understand why this was changed. Today I tried the button from the V-ray toolbar instead of the button from the Rhino toolbar, expecting that it was a mistake of mine not to have used this button, but there was the same problem.
Is there something wrong with my toolbar, is it an old version? Shouldn’t the V-Ray toolbar have _vrayLight … instead of the Rhino _RectangularLight?
(I am using Rhino WIP with VfR 7.)​​
Best-
Micha
Hello @Micha ,
Keep in mind that our installer does not support Rhino WIP yet. We will add the option to install V-Ray on Rhino WIP with the next hotfix. It is not recommended to use a V-Ray for Rhino on another Rhino version - in your case V-Ray for Rhino 7 on Rhino WIP, as the code is often different and some things might not work.
Do you reproduce the issue with other Rhino versions?
Kind regards,
Iva
@iva_mancheva I checked it in Rhino 8 and it’s the same problem. But maybe my VfR toolbar is still an old one and was not updated during the last installation. Could you please also check whether you are using the Rhino command or the VfR command.
I would like it if a light created with the Rhino command could be connected to V-Ray as it used to be. That worked without any problems and now there are always problems.
I still have a Rhino 7 running with VfR 5 and everything is fine there.
Hello @Micha ,
Sorry for the late reply. Here is how it looks like on my side:
Could you please try deleting the V-Ray for Rhino xml file in C:\Users\<username>\AppData\Roaming\McNeel\Rhinoceros\8.0\settings\Scheme__Default and then reopen Rhino 8 and check again?
Thank you in advance!
Kind regards,
Iva
Thank you very much, I have now found out that I must have docked the V-Ray toolbar in mine in the past. It was totally out of date. I found the current one in the options toolbars and it works. :slight_smile:
