I’m having a few issues with placing sound sources in Revit, I keep getting the following errors, the long one is when its placed on a face and the smaller error is when I want to place on a Work Plane, any ideas?
Any ideas @Simon_Weinberger @Jonathan_Knoefel ?
Hi @DanS_1 , I actually don’t have a solution right now. Which version of Enscape and Revit are you using? Does this error occur in every project?
You also can send us Feedback.
@DanS_1 are you using the predefined Enscape sound sources, or are you trying to place your own .wav files?
The workaround for me was to create the first sounds in my project using the predefined enscape sounds, and after that just replacing the sound file!
Thanks for reporting the bug. I guess you are using Revit 2016 and Enscape 1.9.4 or newer. Congratulations, you have hit the only combination with this bug. You can use Revit 2015, 2017 or 2018. Alternatively you can install an older Enscape (1.9.3 or lower).
Latest Preview version of Enscape and Revit 2016. Doesn’t work on an simple file either with just a floor available.
Sounds just right haha! I’ll test it on Revit 2017 instead!
Pretty sure it’s working now, do you know if the sound sources ‘Loop’ at all or do they just stop once the file is done? thinking for ambient outside noise etc
It should loop.
i just had the issue of inserting a .wav file, and the sound would be a loud squeeching sound
HI @Padave , which version of Enscape and Revit are you using?
Can you reproduce it in the same project?
Can you reproduce it with another .wav file?
I’ve had this previously also with the screeching sound, I did cr*p myself the first time it happened!
@DanS_1 what file did you use as the screeching sound appeared and how did you solve it?
Greetings Enscape team,
I am having issues getting the Audio files to work in Enscape. I have followed step by step the tutorial,
using .wav files in different scenes but can’t seem to be able to get it to work. I am experiencing the
issue with both revit 2016 and enscape 1.9.6 and revit 2017 and enscape 2.0. Please advice.
Thank you,
Nicolas
@Nicolas_Ramirez at what exact point of the steps are you experiencing the issues? Are you able to place the sound sources after activating the auralization but the sound isn’t playing or is there already an issue with placing the sound sources?
Hi Jonathan,
I am able to place the sound source and load them into the family, then I am able to copy the sound source file path to the
loaded family but the sound is not playing once I run my enscape.
Thank you,
Nicolas
Having issues still with sound sources, I’ve placed one in my scene and it just crashes revit completely.
Hi @DanS_1 please send us feedback via the [Feedback] button of Revit so that we can check your log files.
