issue to send and edit material from houdini to 3dsmax
Hey guys,
NIce to meet you all, im new in this forum
I m building the environment pipeline at my company and we using 3dsmax and houdini. I try to pass material and lookdev between houdini and 3dsmax using vrscene format . From 3dsmax to houdini it works perfectly, the shader is rebuilt in vray houdini, but when it comes to send a shader from houdini to 3dsmax i can get the shader back as a vrscene which i load in the vrMatMTL but i am unable to edit it. the editor is greyed.
Does anyone has a solution for this? I am also using snippett in 3dsmax but it prove itself quite tricky when it comes to precisely control or tweak a shader for my artists. Does anyone has examples of complex shader vrscne with snippet override to blend 2 displacements, or to blend several triplanar materials?
May be ask in the 3dsmax section then?
Anyway vrscene is not intended to be a transfer format. Consider using USD.
