Issue with my lightmix
zy0SK2x8.html (48.9 KB)
Hi all,
I have an issue my lightmix where i couldnt adjust the intensity of my lights, the boxes are missing. I didnt change the settings and i’m not sure if this is a bug or it has anything to do with my screen resolutions? i have two screens, one is 1920x1080 and the other is 4k. Not sure if the switching of app between the two screens are causing this issue as well.
I’m using 2022 max with corona 13.
Anyone can help? thank you
Regards
We recently released Corona 13 HF 1. Can you check if you get same issue with this version too?
[https://forum.corona-renderer.com/ Chaos Corona 13 (Hotfix 1) now available for 3ds Max and Cinema 4D ](https://forum.corona-renderer.com/ Chaos Corona 13 (Hotfix 1) now available for 3ds Max and Cinema 4D )
If the problem persists, please send us a ticket along with your scene: https://support.chaos.com/hc/en-us/requests/new
This looks like a scaling issue. What system scale do you have in display settings? Can you try with a lower value.
Anyway, if it is reproducible (with high scaling or so), it is a bug and should be reported.
thank you, it was indeed the scaling issue. Silly me. Thanks for the help!
You are welcome.
However the light intensity column should have been visible, it looks a reasonable scaling you had. Can you please tell with which exact settings this appeared?
ah i see, i set my display scaling to 150%
I cannot get VFB sidebar to look like this (trimmed tab text, small icons etc.) no matter what I do.
Maybe it is for multi-monitor setup.
Anyway, I hope the issue is fixed for you.
