Issue with time of day not rendering correctly
I’m having an issue with the time of day not rendering properly this morning - was working fine on Monday!
this is the image I have on screen - via a screenshot - as you can see it is dark outside:
and this is the rendered image via enscape - all of a sudden its light outside!
Not sure what is going on. I’m using Revit R26 and my Enscape version is below:
Any ideas how I fix this?
Not sure if this is the issue here, but lately it seems like what you see in the “live” window is not a reliable representation of what you get when you save out a “screenshot.” It is frustrating.
Hi @JammyML it looks like you had layered export with “Apply Alpha” enabled when creating the rendering. This will make everything that’s in the background of your scene (e.g. sky) transparent. Depending on where you open the .png file this will make the windows appear either white or black, but they’re actually transparent:
You can disable that in your output settings:
Thankyou Clemens, I’ll check it out and let you know if this solves it - must have clicked it on by mistake!
All sorted - Clemens you were exactly correct - I had switched the alpha channel on by mistake.
