I’m not sure if this is a bug or a known limitation.
- create Corona Sky
- activate volume effect in Sky
- create a volume grid like you would use for fire, smoke, or clouds
- if the camera is close to the VDB, the render looks fine
- if I move the camera further away from the VDB, I get a box where the volume effect of the sky doesn’t work.
- it does happen in IR and final
- this gives me a nasty artifact that I need to remove in post
Corona 12 Update 1 Hotfix 1
C4D R20
Win 10
Can you reproduce it?
Hello @lollolo,
Thank you for bringing this to our attention.
Could you please try using the latest Daily build and see if the issue persists?
I tried using the following setup, but couldn’t reproduce it:
-Cinema 4D S26, 2023, 2024, 2025
-Corona latest Daily Build
Looking forward to hearing from you soon.
Kind regards.
Thank you, Benjamin, for your reply. I downloaded the latest daily and tested it again. The issue is still there.
I sent you a PM with a link for downloading the scene and a video.
Thanks and have a nice day
