I am having issues with rendering animations I am using sketch up 2023 with vray , what’s happening is after around the 10th to 14th frame the render speed is halving and gets worse after every subsequent frame. the issue is happening only when I render using cuda and rtx using my rtx 4070, what I have noticed is my gpu dedicated memory starts at around 6 gigs and after every frame it increases by about 0.4 gigs until it reaches the maximum of 12 gigs that my gpu has and then the problems start the only error message that I receive in the log window saying num samples per thread reduced render might be slower. I have tried to render using my cpu and the issue does not occur and the ram stays constant. I am really lost as how to resolve this problem i’m not super tech savvy and would really appreciate any advice with this issue.
