Issues in corona renderer 6
I have downloaded & installed the 45 days trial version of “Corona Renderer 6”. It shows that it installed successfully. But, when i open “3Ds Max 2020” & check the render setup it doesn’t shows on renderer and assign renderer option & the corona renderer toolbar is not visible in UI. I’ve recorded a video for that. Kindly, tell me how to fix it.
Please try uninstalling Corona from the Windows “Programs” list, and then installing it manually like this:
https://coronarenderer.freshdesk.com/support/solutions/articles/12000038849
Let me know if it worked or not. If not, I will provide you with some other solutions.
It got installed (as per your instruction). But, max is getting crashed
Can you please contact us through this form https://coronarenderer.freshdesk.com/support/tickets/new
We will then help you troubleshoot further, and we can also have a Team Viewer session with you.
