Issues with making paths relative with <UDIM> tag
Currently working on a project with tons of udims
Loaded using vraybitmap and adding the <UDIM> tag to the path.
Problem is that i’m transferring this project between systems and 3ds max doesn’t want to make my paths relative.
Relink tools like “Relink Bitmap” doesnt recognize the UDIMs either.
Anyone know how to work with udims in vray across multiple systems?
Where are you storing the textures? Try storing the textures in the same folder as the project, Also which V-Ray version are you using?
