Issues with Object Properties Tag
I use: “Object Properties Tag → Surface Properties → Generate GI Multiplier” in the GPU DR rendering I get a faulty rendering. The object is partially rendered without texture. If I render in CPU mode, everything is fine.
Best regards
uwe
Hello @pardalis ,
The Generate GI Options in the VRayObjectProperties tab do not seem to work with V-Ray GPU and I have already reported the issue to our developers. (Bug number: VC4D-897). I will let you know once we have any updates.
However, during my tests I didn’t experience any issues with partial rendering of textures. Is it possible to share a test scene where the issue is reproducible so we can have a look?
Hello @valentin_leondiev ,
the problem with the texture cannot be reproduced and unfortunately I cannot send you any data because the customer does not give permission.
Best regards
uwe
Thank you for the feedback @pardalis . If you manage to reproduce the issue in a separate test scene that you are able to share with us we will be happy to take a look.
