I have been trying to use a phoenixFDtexmap set to GridViscosity to change a vray material propertues. The texmap does not read the viscosity info for some reason and I can’t understand why. If you see the image you can see the voxel preview changing with the particle tuner, then why can’t the texmap read that info?? Help!!!
Hello Rodrigo,
Saw your post in the facebook group - it’s that the Phoenix Grid and Particle textures are not supported with V-Ray GPU yet. V-Ray CPU should render them properly.
Cheers!
